Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SPA400 and SPA9000 system. cannot use tone with automated phone system
When I call out using a cordless phone plugged into an FXS port I can seam to use the tones after the call is placed.
It makes it difficult to call company's and use there automated phone systems.
Are there any solutions for this?
Re: SPA400 and SPA9000 system. cannot use tone with automated ph
Anyone?
Dear Sir;
I assume you have no issues with the IP phones sending DTMF digits to the same automated system. If it is only related to ths FXS port, this looks like a DTMF level issue. I would suggest you check the [FXS] settings, more detailed, the DTMF Tx Method:and set it to InBand. Then, go to [Regional] Settings, and set DTMF Playback Level:to a larger value, lets say -13. This should solve the issue.
If not, I would suggest you open a case with the support center to perform live troubleshooting.
Alberto
Problem solved. Thank you very much.
667
