Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SPA500DS w/ SPA525G2 UC560
Anyone have any luck with configuring the new SPA500DS with a SPA525G2 running 7.5.2a connected to a UC560 using CCA 3.2.2?
I am having the same problem. The CCA does not have the SPA500DS optioon. If used 500S option, it will works except the display on the 500DS is blank.
I believe the SPA500DS is not supported with UC5XX/CCA. See:
https://supportforums.cisco.com/message/3814992#3814992
Hi All,
As far as I know, SPA500DS has been released for UC560 platform and only compatible with UC560 and SPA500 Series IP Phones.
If I do not use SPA500DS with UC560 platform, Which platform is compatible with SPA500DS ?
1417
