Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SPA502 DEBUG LEVELS
Whats the difference between the different debug levels from 0 - 3?  Its just ive started a syslog server for 4 handsets, 1 SPA9000 & SPA400 & they all use Debug level 3.  But the log files are starting to become pretty large.  Does having a higher debug level cause more log data?
JK
1 REPLY
Re: SPA502 DEBUG LEVELS
There's no doc regarding the different levels.  Generally when there's a problem, we just toggle level 3.
You can experiment doing the same type of call and checking the log file when just using level 1 vs level 3.
For example, when I tried this experiment a while back, I believe level 1 wouldn't show log info regarding the handset when I picked it up but level 3 did.
528
