SPA504 GO DIRECTLY TO SPCP MODE SOFT. VER 7.4.8a
(sorry for my english, hope its understable)
I m having some trouble with the SPA504G IP Phone.
As new phone, I plugged the phone to our poe switch, having TFTP and DHCP,
the phone is now in SPCP mode, asking via tftp to
Oct 03, 2011 15:50:41 Session 1, Peer 172.27.1.2 TFTP Server session started
Oct 03, 2011 15:50:41 Session 1, Peer 172.27.1.2 Client requests GET of file D:\Oswaldo\Confidencial\Diagnostico\Cisco\SIP\Hosted IP PBX\cfgxml\SEP30E4DB80732C.cnf.xml.
Oct 03, 2011 15:50:42 Session 1, Peer 172.27.1.2 Could not open requested file for reading
Oct 03, 2011 15:50:42 Session 2, Peer 172.27.1.2 TFTP Server session started
Oct 03, 2011 15:50:42 Session 2, Peer 172.27.1.2 Client requests GET of file D:\Oswaldo\Confidencial\Diagnostico\Cisco\SIP\Hosted IP PBX\cfgxml\XMLDefault504G.cnf.xml.
Oct 03, 2011 15:50:42 Session 2, Peer 172.27.1.2 Could not open requested file for reading
Oct 03, 2011 15:50:42 Session 3, Peer 172.27.1.2 TFTP Server session started
Oct 03, 2011 15:50:42 Session 3, Peer 172.27.1.2 Client requests GET of file D:\Oswaldo\Confidencial\Diagnostico\Cisco\SIP\Hosted IP PBX\cfgxml\XMLDefault.cnf.xml.
Oct 03, 2011 15:50:42 Session 3, Peer 172.27.1.2 Could not open requested file for reading
So, I have try this:
-Factory reset: not successfull, the telephone still asking for the XMLDefault, not for the spa504.cfg.
In the TFTP Server, only I have that file spa504G.cfg with the following:
Any idea how can i change this phone again to SIP Mode ? I have read the zero-touch tutorial and have not found information about this,  and back to the spa504g.cfg provisioning mode ... ?
I attach, the pcap file.
Thanks !!!
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hi Oswaldo,
The phone does not appear to be in SPCP mode based on the Log.pcap.zip file.
I do see the following:
Packet frame 16, the 172.27.1.1 DHCP server offers a very strange OPTION 66 of:
The TFTP server name should be an IP address or FQDN of the TFTP server.
The phone is not looking for /spa504G.cfg or /Cisco/SPA504G/.cfg because it does not have a valid TFTP server to send a request to.
Once you send the phone a valid OPTION 66, the phone will request its SIP configuration files.
Patrick
I make a upgrade to 7.4.9a, that not fix my issue.
Hi Oswaldo,
Patrick
I change the DHCP Server to Router Cisco, and is the same situation, later i try with DHCP Turbo, and it work fine.
In my router i have that
ip dhcp pool Phone_AR7
   network 172.27.1.0 255.255.255.0
   default-router 172.27.1.10
   option 66 ip 172.27.1.210
How can I set the TFTP Server Name...?
I found it, the correct configuration in the router Cisco.
ip dhcp pool Adtran_AR14
   option 66 ascii "172.27.1.10"
1821
