01-24-2013 12:01 PM - edited 03-21-2019 06:52 AM
I bought a spa500ds and need to upgrade the firmware on my 508G to use it.
When I try to upgrade to 7.5.4, or 7.5.3 I get a failure. I was able to upgrade to 7.5.1a fine. All firmware was downloaded from cisco this morning and unziped
I see my tftp server giving the file.
I get upgrade failed: 12. corrupt file in my syslog
Any idea where to look next?
Solved! Go to Solution.
01-25-2013 02:41 AM
It states on the release notes of 7.5.4, that upgrading from 7.5.1a you should first upgrade the phone to 7.5.2b.
Have you done this upgrade step?
Joao
01-25-2013 02:41 AM
Joao
01-25-2013 08:50 AM
That was it. I missed that in the docs, thanks
