Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SPA508G pairing with Plantronics C65
Does anyone know if it is possible to use this combination and how? Can't find anything re a 508G on the plantronic support site, and the 50x support guide does not really describe anything about this, just refers to plantronics website.
Thanks.
I don't think the 508 supports bluetooth pairing, but you can plug wired headsets into it.
Se if this doc helps,
Headset Compatibility for SPA303, SPA5xxG and SPA9xx Phones
https://supportforums.cisco.com/docs/DOC-9926
and this one
Headset_Plantronics_Linksys_v10.pdf
https://supportforums.cisco.com/servlet/JiveServlet/download/9926-8-66695/Headset_Plantronics_Linksys_v10.pdf
Hi Mogens,
I'm not familiar with the Plantronics C65. I searched and found this page which says that the device registers as a DECT handset using GAP:
http://www.landlinephones.co.uk/product.php?pinf=988-5--Plantronics_C65_DECT_wireless_headset--
The SPA508G does not have a DECT base station so cannot support this particular handset.
Patrick
1108
