Community Member
SPA509G - Arrange Shared FXO Extensions
I'm looking to arrange all 4 of my incoming lines (Shared FXO Entensions) to the left side of my SPA509G.  By default it looks like it puts them it its own order.  How can I move these?  Otherwise I'm stuck with the phone extension at the top right then 3 Incoming lines and the 4th Incoming line is by itself on the top left.
Thanks in advance for the help.
Community Member
You can move the config.  Log into the phone via the web browser, as admin/advanced.
Go to the phone tab.  You'll see Line Key 1 is mapped to Ext 1.  This goes on like this through Line Key 12.
Just set Line Key 5 to map Ext 1.  And do this for the other line keys tha you want moved.  If you don't want to use the Line Keys on the right side, set the Line Key 1 to 4 as disabled.
Community Member
How exactly do I do this?  I see the line Keys and the extensions, but I don't see a place to make any changes.
Thank you
VIP Blue
You need to be logged in as admin, not user.
258
