SPA509G with SPA9000 EXT 2 not transferring to voicemail.
Here is my issue.
     I have a SPA509G with two extensions connected to a SPA9000/SPA400.
               EXT 1 (200) - works as described, caller calls in, phone rings 5x then transfers to voicemail.  DND transfers to voicemail as well, and so does                               hitting the ignore button.
               EXT 2 (211) - Goes like this.   Caller calls in, phone rings 20x then hangs up.  DND rings busy, however pressing the ignore button transfers                               the caller to voicemail.
     **both extensions have direct dial numbers tied to them.  You can dial into both voicemail boxes.
Thoughts?
1 REPLY
Re: SPA509G with SPA9000 EXT 2 not transferring to voicemail.
The user tab which controls the call forward all, busy and no ans, only does this for ext 1 and not the other ext's.  So this is working as designed.
459
