Community Member
SPA525G - FW 7.4.4 Bluetooth headset problem
I am using a Plantronic Voyager PRO or Nokia HS-36W headset.
Parring is ok as well as call pick-up and release.
But after some use it drops calls at pick-up.
It also goes from BT headset (blinking headset lamp) to headsset jack (steady lamp) at pick-up.
Only a power recycle of the SPA525G will recover for BT headset use.
To me it clearly seems to be a FW bug.
Any views?
Flemming, Denmark
Re: SPA525G - FW 7.4.4 Bluetooth headset problem
Dear Sir;
Yes, we have detected the bug. We are working for a resolution on this subject (new FW). As soon as available (dont have an estimate yet), will let you know
Alberto
Community Member
Do we have any solution here kow?
Dear Sir,
Please download and use 7.4.6, it should solve your issue. SW is available on cisco.com
Alberto
Community Member
I have the same issue with the Bluetooth Headset.  I can work around this by unpairing the phone and re-pairing the headset with the phone. I have to do this when my multi-point headset answers another phone, or go out of range.  A reboot is not necessary though.  You can go to to bludetooth configuration, bluetooth profile, option, unpair | then option, pair.  This is the quickest way.
Michael
1025
