Community Member
spa8800 slow call routing & firmware info
1. Is there any way or parameter setting to speed up call routing to
PSTN line ? When number is dialed on phone connected to FXS
and routed via FXO there more then 5 seconds need to receive
ring-back from outside public PBX.
We tried  adjust Interdigit Long Timer: to 1 and Interdigit Short Timer: 1
result is the same. Is there any other parameter which can be adjusted to
speed up this dialing.
2. One question about firmware ?
Current firmware is
Cisco SPA8800 IP Telephony Gateway with 4 FXS and 4 FXO Ports
Voice Gateway Firmware-6.1.7
there also exist
Analog Telephone Adaptor (ATA) Firmware-6.1.11
Can someone from Cisco explain what is difference and can both of them used on same device or not ?
3. Voice quality on that device definitly is not on Cisco standards.
Especially when the call is routed  from FXS port to the FXO ports.
FXO side look problematic related to voice quality.
Slavko
173
