SPA9000 and SPA8800 integration
I would like to help in integrating the SPA9000 with SPA8800.
The scenario I have is the following:
- 1 SPA9000
- 1 SPA8800
- 2 SPA525G (IPPhone)
All devices are connected to a switch 3560G PoE, the network has no VLAN configured and is dedicated to the telephone system.
I would like to integrate the system with a PSTN line for testing.
The SPA9000 is already registering the phones, making calls intrasite, but can not integrate with the SPA9000 SPA8800 to make external calls (PSTN)
1 REPLY
Re: SPA9000 and SPA8800 integration
Dear Sir;
This configuration is not supported (so no documentation) but my work properly if you dont require voicemail functionality.
Each SPA8800 Line shall be configured peer-to-peer to each SPA9000 line. Both devices should have a static IP address for this purpose. Remember to set No registration at both ends and use the right ports.
Alberto
725
