Community Member
spa9000 - problem sending fax
I've install a spa9000 solution with a gateway isdn mediatrix 4402  - point to point protocol. This installation works with 6 phones spa962 and a big ricoh copier for the fax on the analog port.
All seems to work good except the sending of fax.
Sometimes the fax is not send and i receive a "line error" report. It depend on the number i call.
Some numbers always work perfectly and others never work.
It seems to be a problem with the fax of the callee (for example: i call the same customer on two different numbers to test on 2 different fax machines and it works on the first and not on the other). When the problem occur, the transmit never start and the call is ended.
An idea of a config to solve this ?
Re: spa9000 - problem sending fax
Hi Patrice:
Are the two fax numbers similar? Are they connected through same line types?
Alberto
Community Member
Hi, first, thx for that fast react !
The two faxes are different models on different numbers. For the type of lines i dont know.
Indeed i think that i have the problem only with some pstn lines (not all).
695
