Community Member
SPA922 IP Phone one way call problem
Hi, we have a few types of IP phones deployed in the field.  Currently we're experiencing a problem with a Planet VIP-103PT phone calling a Cisco SPA922 phone:
  • When a Planet VIP-103PT initiate a call to a Cisco SPA922 (firmware 6.1.5a), upon answering, no voice can be heard on both ends.
  • But the other way around, a Cisco SPA922 calling a Planet VIP-103PT, everything works normally.
Any idea what the problem might be?  Thanks!
Re: SPA922 IP Phone one way call problem
Dear Sir;
This may have to two with two things (provided there are no nat issues):
- Packetization time is not matching
- Codec naming issues.
I suggest you check and the traces and ensure that codec and packetization time configuration is the same for both phones.
Alberto
Community Member
Thanks for the suggestion.  As it turned out, it's a bug in the Planet phone's firmware.  After installing their beta firmware, the problem is solved.
2087
