Community Member
Speed dial using press and hold line key on 500S sidecar
Speed dial: press and hold idle line key
Will this functionality be enable with the 500S side car ?
Community Member
Re: Speed dial using press and hold line key on 500S sidecar
If you have configured this in the extended function parameter of the phone (in phone tab) then you should see the same functionality in the sidecar.
Community Member
Of course by configuring this functionality through the web interface it works well. But you can, on each phone of the spa5xx serie, by pressing 3 seconds on an unused line add manualy a spedd dial, on the 500S sidecar you cannot do it manually.
Community Member
Thank you for the input, I'll submit a feature request on this issue.
592
