Community Member
Speed Dials on a Sidecar
basically my client wants to use his sidecar to store speed dials to his external num
bers like his home, etc.  They are under his directory and personal speed dials but is there a way that he can just press a
button on the side car (or phone) that is not in use and have the speed dial numbers dialed?
1 REPLY
Re: Speed Dials on a Sidecar
I can offer some feedback here and will use the CCA configured system as the example.
We have two areas in CCA Expert Mode:
CONFIGURE Drawer:  Telephony- Voice Features:
-System Speed Dial
-Personal Speed Dial
System Speed Dial
Entries show up on everyones phone in the Local Speed Dial area (must navigate on the phone to get to these):
  • 79xx :  Local Services Hard Button (the open book button):C Local Speed Dial
  • SPA5xx: Settings Hard Button (dogeared page button): Directories, Corporate Directory, Local Speed Dial
An XML file is transferred to flash in this case containing all the numbers and button assignment that appear in here.
Personal Speed dial
These will appear on the phone buttons, if there is an available button.   It occupies the next free button slot.  if you adjust the phone button configuration, it will move as lower priority to the next free spot.
If it cant be displayed on a phone button, it will also appear inside the following area:
  • 79xx: CME Services hard key (Globe Button): MyPhoneApps:  Speed Dial Buttons
  • SPA5xx: Settings Hard Button (dogeared page button): CME Services: MyPhoneApps:Speed Dial Buttons
Sends:
ephone
speed-dial 1 919193922000 label "Jims Cell"
restart
When dealing with a 500S side car, since its paper label, you have to add a step to figure out where it landed so you can lable that button.
https://supportforums.cisco.com/message/3085286#3085286
Steve
676
