step by step how to activate BE6000 license???
this is the 1st time to activaite license for BE6000
please i need your help step by step in activaiting license for BE6000(with 3 servers configured CUCM, CUC & SUP).
thanks
Andrew Hickman
Please take a look at the Enterprise Licence Manager User Guide for details on how to install licenses.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/elmuserguide/9_1_2/CUCM_BK_E92F409A_00_elm-user-guide-912.html
ELM is installed by default with both UCM and Unity Connection. You should use only one instance to manage your licences - I'd suggest the one installed with UCM (although it makes no difference) - then ignore the other one.
Andy
