Community Member
Struggling to get 2 x UC560s networked together
I am struggling to get 2 x UC560 devices networked together . I was under the impression that as long as there was link between WAN ports the units would work together .
Hall of Fame Super Gold
Re: Struggling to get 2 x UC560s networked together
Sure, but it's not automatic, far from that.
Configuration It require specific experience and/or Cisco certifications.
Do you have that ?
Community Member
Hi Alen,
Are you using CCA?
If so then this should be an almost straight forward process, you can use CCA to create intersite connectivity by creating the configuration on the one system which will be the primary one, and then CCA will produce a script file that you can use on the second system (Again using CCA to re-upload this script file), CCA should take care of both sites.
You may also need to use CCA to create the VPN tunnel between the two sites to ensure that security is tight and done right, and to ensure it complies with standard practices.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
369
