Community Member
Suitable Headset for Linksys SPA921 IP Phone
My apologies in advance for this not very technical question.
I have had a hard time finding a working solution for this. As the RJ-11 connection is broken on my phone, I need a headset to replace and to plug into the 2.5mm jack. I've tried a few, but they never quite worked (the other person could not here me etc.). I've found one that should work according to the manufacturer, which is the following:
Jabra GN2000 Mono Soundtube Headset
I just find it a bit expensive, as it costs more than the phone itself, but it's the cheapest I've found. Does anyone know what are the exact characteristics required? I believe the 2.5mm jack should be mono, that might have been the problem with the last ones I tried.
I would greatly appreciate if you could provide me with the exact specs or perhaps recommend some cheaper products instead.
Thank you very much in advance.
Everyone's tags (4)
