Community Member
Transfers on SPA-932
When using a SPA-932 attached to an SPA-962, I am trying to figure out how to perform a transfer on an Asterisk PBX. I have tried setting fnc=sd;sub=#700@asterisk-ip on one of the line keys where # is the transfer key and 700 is the extension to transfer to (call park).  However when the button is pressed, it happens so quickly that the transfer doesn't register past the # digit, resulting in a failed transfer.
Is there a way to introduce a delay here or does anyone have any other suggestions on how to achieve one button call parking with this setup and Asterisk?
Thanks in advance!
1 REPLY
VIP Gold
If I understand correctly, you are wishing to insert a pause between # and 700.
Unfortunatelly, no goot news for you. It is possible on SPA[35]xx phones starting with 7.5.1 firmware, but I suspect the SPA9xx is so old to support it.
As a very dirty hack, you can change string to something like
sub=#0000000000000000000000700
then modify Asterisk's extension conf to ignore all but last three digits.
247
