UC 520 Key system configuration
I have a system that the customer wanted setup as a key system for a variety of reasons. Now they want call forwarding. I noticed on one thread that you had to recreate the trunks to make this happen. Being relatively new to cisco IOS, can anyone explain that in a bit more detail? It looks like the lines are dual-line, but I think the author might have meant something else about recreating the trunks. If you have a sample bit of what it should be like, that would be great.
Thanks!
Matt
1 REPLY
Silver
Re: UC 520 Key system configuration
This is designed for the CCME, but it will work fine for the UC520 via command line, and it won't be as confusing to you.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmepark.html#wpmkr1010647
146
