UC 560 over writing the default AA script
Is there a way to over write the default AA script? I have tried through the CUE web interface and also CCA. I need to change the time that the script waits for a user to enter a character for the dial by name directory. I have used the CUE editor to adjust the script but I can not seem to load the update using the same name as the default script. I was able to load it with a different name but then you do not get the area to set parameters for dialing numbers, pound or star.
178
