03-29-2012 06:19 PM - edited 03-21-2019 05:35 AM
Hello
I have UC560 with 2 vic cards for 2 T1, and the configuration that I need is this:
The long distance call has to go for the First T1
Local calls for the second T1
and also I need a failover, If one of the T1 fails used the another one.
Any help please because I new on this platform.
03-30-2012 01:54 PM
Have you looked at Outgoing Dial plan in here
03-30-2012 11:58 PM
You can use the priority within CCA for outgoing dial plan.
If you are EUC or higher you can do this within the dial peers themselves.
