ā05-30-2011 03:48 AM - edited ā03-21-2019 04:10 AM
Hi All,
I noticed that in Cisco UC320W there is only the option "User ID" as authentication method when configuring SIP trunk with the Telco providers. In my case the most of the local providers (Bugaria) doesn't support/offer this method of authentication. Most of the providers here offer only "IP base authentication" with separŠ°te VLANs and so on.
In Cisco UC5xx I can easily configure it, but it's seems impossible in UC3xx. Here is an example in UC5xx:
interface FastEthernet0/0
description $FW_OUTSIDE$
ip access-group Outside_Accesss_In in
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1482
description *** INTERNET ***
encapsulation dot1Q 1482
ip address 95.43.243.186 255.255.255.248
ip nat outside
ip virtual-reassembly
crypto map TEST_stmap
interface FastEthernet0/0.2651
description *** FIXED SIP TRUNK ***
encapsulation dot1Q 2651
ip address 10.102.0.130 255.255.255.252
Do you have any ideas how can I bypass this? Does cisco plans to set this option with upcoming feature release?
Velin Tsekov
Solved! Go to Solution.
ā05-31-2011 08:55 AM
Hi Velin,
Sorry, I missed that part of your question. There are several feature requests under consideration for an upcoming feature release for VLANs and IP routing. One of which is to support VLANs on the WAN interface.
Chris
ā05-31-2011 07:18 AM
Hi Velin,
The UC320W does support providers with IP based authentication, however, we do not support VLANs on the WAN interface in the 2.0 firmware release.
Chris
ā05-31-2011 07:35 AM
Hi Christopher,
Thank you for your reply!
Does Cisco plans to support VLANs on UC320 in the future firmware releases?
And I'll be more than grateful If you can give me an example how can I configure/use the "IP authentication" method? As I can see in the wizard I've Š° mandatory field "account id"?
I've an idea to bypass this with configuring one ESW/C300 Switch before UC320.
Velin Tsekov
ā05-31-2011 08:42 AM
Hi Velin,
You simply uncheck the 'Require Registration' checkbox on the SIP/BRI Trunks page. This will allow calls to work (both directions) without SIP registration.
Good idea putting a switch on the WAN side. You could make the port connected to the UC320W an access port on the VLAN that is required and then make the port to the ISP your 802.1q trunk. Do make sure you have strong password on the switch.
Chris
ā05-31-2011 08:50 AM
Thanks again. I'll try this tomorrow.
And last do you know whether cisco has plans to support VLANs on this UC model or not?
Cheers,
Velin
Hi Velin,
Chris
ā05-31-2011 08:58 AM
Thanks for your information!
Cheers,
Velin
