UC320 - web interface issue
When I try to access the web interface from Firefox it says "Cisco UC320 Firmware Upgrade Application" then in the center of the screen has a Cisco progress bar nothing ever happens. From IE it says "Cisco Configuration Utility" but the Cisco bar is way up in the top left.  Anyone ever run into this issue?
1 ACCEPTED SOLUTION
Hi Delvin,
I think you are hitting the Adobe Flash Player 11 issue.  See this link for issue and workarounds:
https://supportforums.cisco.com/message/3478189#3478189
Chris
Hi Delvin,
Chris
Good job, that was the issue I down graded to Flash 10.1 and can access the web interface login.
872
