09-23-2011 05:59 AM - edited 03-21-2019 04:42 AM
I have installed a Cisco UC320 with several 504G Stations running the current firmware - 2.1.1
The SLA on one of the phone's shows that another user is constantly on the phone, even when they are not. Is this a known bug? Or has anyone experienced this issue. Things will work correctly for a while after a system reset, but then the phones will stop updating the SLA status. Eventually this will happen accross all four of the 504g's that we are using.
thanks
09-23-2011 06:26 AM
Hi Rodney;
This typically happens when the switch is blocking multicast traffic. Please check the storm control /security settings of the switch and disable multicast from it (storm control = broadcast only). Save/apply the config and the system should stabilize.
Alberto
09-26-2011 11:33 AM
Thanks for the pointer Alberto, I made the update and will monitor too see if that resolves out issue.
