Community Member
UC320W - FW2.3.2 - General SIP Trunk - SIP domain setting missing
I would like to create a SIP Trunk for the german Telecom.
I am using a UC320W with the latest Firmware 2.3.2 and the region is set to germany.
The SIP setting for the german Telecom requires to set the SIP domain.
Should not be a problem, but when I try to create a new SIP Trunk based on a general provider the SIP domain field is missing in the form.
So I am not able to set this value and therefore the connection cannot be established with a blank domain.
I have tried to downgrade the Firmware to 2.2.2 with the same result.
In some documents of the UC320W I have found screenshots, where a field for the SIP domain is available.
Does someone has the same issue and knows how to fix it?
Is it related to the german region? Or is it possible to set the SIP domain in different way?
Any help is more than welcome!!!!
Thanks in advance...
