03-31-2012 04:49 AM - edited 03-21-2019 05:35 AM
Hi all,
I am a new Cisco enthusiast and presently an end user. I have embarked on a learning adventure with networking and jumped in with both feet.
I have the following hardware:
Cisco 887VA Integrated Services Router
Cisco ES520 series 8 port switch
Cisco UC320W appliance (of course)
I had the router as part of my existing data network and so I followed the Greyfield Smart Design guidelines for voice only service.
I have selected this topology and have my connections as per the guidelines.
Summary:
Cisco 887VA (fast ethernet port 3) ---- VLAN 4 ----- (WAN port) UC320W
I have configured the 887 with the IP address 192.168.2.253 with mask 255.255.255.252 on vlan4.
On the WAN page of the UC320W I have configured it with IP address 192.168.2.254 and mask 255.255.255.252. I have set the gateway as 192.168.2.253. My DNS servers etc are from the ISP.
My router config for the setup is:
interface FastEthernet3
switchport access vlan 4
switchport mode trunk
no ip address
interface Vlan4
ip address 192.168.2.253 255.255.255.252
ip nat inside
ip virtual-reassembly in
ip nat inside source static tcp 192.168.2.254 8080 interface Dialer0 8080
Now when I try to ping the UC320W from the router I get no response:
cisco#ping 192.168.2.254
Sending 5, 100-byte ICMP Echos to 192.168.2.254, timeout is 2 seconds:
Success rate is 0 percent (0/5)
and from the PING tool in the UC320W web interface the same:
PING 192.168.2.253 (192.168.2.253): 32 data bytes
From 192.168.2.253 icmp_seq=0 timed out
From 192.168.2.253 icmp_seq=2 timed out
From 192.168.2.253 icmp_seq=3 timed out
--- 192.168.2.253 ping statistics ---
6 packets transmitted, 0 packets received, 100% packet loss
I cannot access the WAN port from anywhere.
What am I doing wrong? Any suggestions? Please feel free to make any or ask any further questions.
Solved! Go to Solution.
03-31-2012 10:04 AM
Hi Ben,
First of all, there is a PMF file to allow ping on the UC's WAN port.. It's blocked by the UC's firewall by default.
https://supportforums.cisco.com/docs/DOC-16301
Try setting your Fa3 port to access.. It's a trunk at the moment. You're config is a little mixed up.
switchport mode access
FYI - If you need a port to be a trunk in the future with a different native VLAN(default is 1). Here is how you would do it..
switchport trunk native vlan 4
Finally, double check your UC's remote access port is actually 8080 and that remote access is enabled through the GUI.
Hope it helps
Matt
03-31-2012 10:04 AM
Hi Ben,
Hope it helps
Matt
03-31-2012 03:13 PM
Hi Matthew,
Thank you for your response.
I made the changes and applied the PMF. I can now ping the UC320W successfully from my router and other computers in the network.
I can also access the configuration from the WAN port now also which I couldn't before the ping started working. That remains a little mysterious as I would have thought the appliance would have responded despite filtering the pings.
Anyhow it all works now so I'm very pleased.
I could make and receive calls before by the way; but the lack of a response was disturbing; even though the WAN status was showing received and transmitted packets.
Thank you again.
04-01-2012 03:34 PM
Glad to help. Have fun!
Matt
