UC500 - 7942 Phone Display
Quick question regarding the phone display on the 7942.  In the upper right-hand corner the user's name is displayed.  Can this be configured through CLI or does it need to be done via CCA?
Thanks in advance for the help.
Jeff
Re: UC500 - 7942 Phone Display
I believe you refer to the ephone-dn CLI paramter called "description", which CCA sets for you as the Firstname/lastname as buit in CCA.
The configuration on the ephone-dn is:
ephone-dn  17  dual-line
number 5584352 no-reg primary
label 4352
description Bryan Gran
name Bryan Gran
call-forward busy 5584362
call-forward noan 5584362 timeout 18
When the 4352 is dialed it displays the name "Bryan Gran" and in the corporate directory it is listed as "Bryan Gran", however; on the physical phone with the 4352 extension it still displays the previous user's name in the upper right-hand corner.
Jeff
have you reset the phone after making changes?
Check how it looks in CUE GUI (10.1.10.1) as well...
It was in fact that I had forgotten to restart the phone.
Thanks again.
Jeff
Happens all the time to us too. But CCA does it for us :) <-- shameless CCA Plug :)
I may have forgotten to reset the phone.  I will do that when I get the all clear from the user.  I only have access to the CLI, I am not on their physical network and do not have vpn access to view the gui.  We'll see if a restart fixes the issue.
I'll let you know.
Thanks again for your time and suggestions.
Jeff
524
