Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
UC500 AA impact on voicemail
I have a UC500 that worked wonderful for the past 3 years. Suddenly a strange issue appeared....I have one number routed to the AutoAttendant with several options. After the caller chooses the destination if it happens that the called party is busy or not at the desk is routed to the voicemail as is supposed too...Now here comes the strange part ...after the prompts and the "beep" to leave the message,  nothing is recorded and no notification is sent out..basically the message is lost...
If i change the routing to a group blast instead of the AutoAttendant when i get to any voicemail box it works perfect.
I would appreciate any idea where to start or what to look into .
Thank you
Here is my config ( edited some info out) as guide ( DTMF optiions like # wont work when in voicemail with AA active)
version 12.4
parser config cache interface
no service pad
no service timestamps debug uptime
service internal
service compress-config
service sequence-numbers
hostname UC520
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-20.T2
boot-end-marker
logging message-counter syslog
logging buffered 4096
no logging rate-limit
enable secret 5 <removed>
aaa new-model
aaa group server radius radius_local
server 192.168.10.1 auth-port 1812 acct-port 1813
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authentication login auth_method_radius_local group radius_local
aaa authorization exec default local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa accounting update periodic 10
aaa accounting network acct_method_radius_local start-stop group radius_local
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-1097906774
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1097906774
revocation-check none
rsakeypair TP-self-signed-1097906774
crypto pki certificate chain TP-self-signed-1097906774
certificate self-signed 01
  <cropped>
            quit
dot11 syslog
dot11 ssid
   vlan 2
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 0
dot11 ssid
   vlan 1
   authentication open
   wpa-psk ascii 0
dot11 ssid uc520-voice
   vlan 100
   authentication open
   wpa-psk ascii 0
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.200 192.168.10.254
ip dhcp excluded-address 192.168.20.250 192.168.20.254
ip dhcp excluded-address 192.168.20.1 192.168.20.2
ip dhcp excluded-address 192.168.20.250 192.168.20.255
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
   dns-server 4.2.2.1 4.2.2.1
ip dhcp pool guest
   network 192.168.20.0 255.255.255.0
   dns-server 4.2.2.2 4.2.2.1
   default-router 192.168.20.1
ip name-server 75.75.76.76
ip name-server 75.75.75.75
ip inspect log drop-pkt
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic timeout 300
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
trunk group  ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme sequential
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 3600 min 3600
   outbound-proxy ipv4:66.23.129.253:5060
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
voice class cause-code 1
no-circuit
voice hunt-group 2 parallel
final 258
list 206,230
timeout 16
pilot 512
voice hunt-group 3 parallel
final 257
list 202,203,205,266,207,210
timeout 16
pilot 513
voice translation-rule 1
voice translation-rule 4
rule 1 /mysecondarynumber/ /513/
voice translation-rule 5
rule 1 /1"mynumberishere"/ /513/
voice translation-rule 410
rule 1 /^8\(.*\)/ /\1/
rule 15 /^...$/ /"mynumberishere"/
voice translation-rule 411
rule 1 /^8\(.*\)/ /ABCD8\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 15 /.*/ /"mynumberishere"/
voice translation-rule 1112
rule 1 /^8\(.......$\)/ /1239\1/
rule 2 /^8/ //
voice translation-rule 1113
voice translation-rule 1115
rule 1 /^8\(.......$\)/ /\1/
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^81900......./ //
rule 2 /^81976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile InboundDirect-BG_Called_5
translate calling 3265
translate called 5
voice translation-profile KTP-BG_Called_4
translate called 4
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice translation-profile pstnfxo1
translate redirect-called 1115
voice-card 0
no dspfarm
license feature uc500-16u-upgrade
username admin privilege 15 secret 5 <removed>
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key btgvpn_2154
dns 255.255.255.255
pool SDM_POOL_1
acl 105
save-password
max-users 10
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
   virtual-template 3
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
archive
log config
  logging enable
  logging size 600
  hidekeys
process-max-time 50
ip tftp source-interface Loopback0
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
class-map match-any media
match  dscp ef
class-map match-any signaling
match  dscp cs3
match  dscp af31
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
policy-map queue
class signaling
    bandwidth percent 5
class media
    priority percent 25
class class-default
    fair-queue
policy-map shape
class class-default
    shape average 5000000
  service-policy queue
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.0
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
bandwidth 10000
ip address "mypublicip" 255.255.255.248
ip access-group 107 in
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
service-policy output shape
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group$FW_INSIDE$
ip unnumbered Loopback0
ip access-group 100 in
ip nat inside
service-module ip address 10.1.10.1 255.255.255.0
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
encryption vlan 100 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
ssid yyy
ssid yyyyy
ssid uc520-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
service-policy output Voice
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Virtual-Template3 type tunnel
ip unnumbered BVI1
ip access-group 102 in
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
no ip address
bridge-group 2
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 103 in
ip nat inside
interface BVI2
ip address 192.168.20.1 255.255.255.0
ip access-group 106 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 104 in
ip nat inside
ip local pool SDM_POOL_1 192.168.11.1 192.168.11.10
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 75.151.40.126
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip route 192.168.10.0 255.255.255.0 192.168.10.254
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source list 1 interface FastEthernet0/0 overload
logging 192.168.10.11
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.255
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 66.23.129.253
access-list 2 permit 192.168.10.1
access-list 2 permit 192.168.10.0 0.0.0.255
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 2 deny   any
access-list 100 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip 192.168.20.0 0.0.0.255 any
access-list 100 deny   ip 10.1.1.0 0.0.0.255 any
access-list 100 deny   ip "mypublicsubnet" 0.0.0.7 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_10##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host 10.1.10.2 eq non500-isakmp
access-list 101 permit udp any host 10.1.10.2 eq isakmp
access-list 101 permit esp any host 10.1.10.2
access-list 101 permit ahp any host 10.1.10.2
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip 192.168.20.0 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip "mypublicsubnet" 0.0.0.7 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.255 any
access-list 102 deny   ip 192.168.20.0 0.0.0.255 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip "mypublicsubnet" 0.0.0.7 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any host 192.168.10.1 eq non500-isakmp
access-list 103 permit udp any host 192.168.10.1 eq isakmp
access-list 103 permit esp any host 192.168.10.1
access-list 103 permit ahp any host 192.168.10.1
access-list 103 deny   ip 10.1.10.0 0.0.0.255 any
access-list 103 deny   ip 192.168.20.0 0.0.0.255 any
access-list 103 deny   ip 10.1.1.0 0.0.0.255 any
access-list 103 deny   ip "mypublicsubnet" 0.0.0.7 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_11##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit udp any host 10.1.1.1 eq non500-isakmp
access-list 104 permit udp any host 10.1.1.1 eq isakmp
access-list 104 permit esp any host 10.1.1.1
access-list 104 permit ahp any host 10.1.1.1
access-list 104 permit tcp 10.1.10.0 0.0.0.255 any eq 2000
access-list 104 permit udp 10.1.10.0 0.0.0.255 any eq 2000
access-list 104 deny   ip 10.1.10.0 0.0.0.255 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip 192.168.20.0 0.0.0.255 any
access-list 104 deny   ip "mypublicsubnet" 0.0.0.7 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip any any
access-list 105 remark SDM_ACL Category=4
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
access-list 106 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 106 remark SDM_ACL Category=1
access-list 106 permit udp any host 192.168.20.1 eq non500-isakmp
access-list 106 permit udp any host 192.168.20.1 eq isakmp
access-list 106 permit esp any host 192.168.20.1
access-list 106 permit ahp any host 192.168.20.1
access-list 106 deny   ip 10.1.10.0 0.0.0.255 any
access-list 106 deny   ip 192.168.10.0 0.0.0.255 any
access-list 106 deny   ip 10.1.1.0 0.0.0.255 any
access-list 106 deny   ip "mypublicsubnet" 0.0.0.7 any
access-list 106 deny   ip host 255.255.255.255 any
access-list 106 deny   ip 127.0.0.0 0.255.255.255 any
access-list 106 permit ip any any
access-list 107 remark auto generated by SDM firewall configuration##NO_ACES_23##
access-list 107 remark SDM_ACL Category=1
access-list 107 permit udp any host "mypublicip" eq non500-isakmp
access-list 107 permit udp any host "mypublicip" eq isakmp
access-list 107 permit esp any host "mypublicip"
access-list 107 permit ahp any host "mypublicip"
access-list 107 deny   ip 10.1.10.0 0.0.0.255 any
access-list 107 deny   ip 192.168.10.0 0.0.0.255 any
access-list 107 deny   ip 192.168.20.0 0.0.0.255 any
access-list 107 deny   ip 10.1.1.0 0.0.0.255 any
access-list 107 permit udp host 75.75.76.76 eq domain any
access-list 107 permit udp host 75.75.75.75 eq domain any
access-list 107 permit icmp any host "mypublicip" echo-reply
access-list 107 permit icmp any host "mypublicip" time-exceeded
access-list 107 permit icmp any host "mypublicip" unreachable
access-list 107 permit udp host 66.23.129.253 eq 5060 any
access-list 107 permit udp host 66.23.129.253 any eq 5060
access-list 107 permit udp host 192.168.10.1 eq 5060 any
access-list 107 permit udp host 192.168.10.1 any eq 5060
access-list 107 permit udp any any range 16384 32767
access-list 107 deny   ip 10.0.0.0 0.255.255.255 any
access-list 107 deny   ip 172.16.0.0 0.15.255.255 any
access-list 107 deny   ip 192.168.0.0 0.0.255.255 any
access-list 107 deny   ip 127.0.0.0 0.255.255.255 any
access-list 107 deny   ip host 255.255.255.255 any
access-list 107 deny   ip host 0.0.0.0 any
access-list 107 deny   ip any any log
access-list 110 remark SDM_ACL Category=16
access-list 110 permit ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.15
radius-server local
  nas 192.168.10.1 key  <removed>
  user client nthash 0 564E293CC972FD0DB2C7F9547CE47C67
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.10.1 auth-port 1812 acct-port 1813 key <removed>
control-plane
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 100 route ip
call threshold interface FastEthernet0/0 int-calls low 5 high 5
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
shutdown
voice-port 0/0/2
shutdown
voice-port 0/0/3
shutdown
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 299
description Configured by CCA 4 FXO-0/1/0-Custom-AA-OP
caller-id enable
voice-port 0/1/1
shutdown
description Configured by CCA 4 FXO-0/1/1-Custom-AA-OP
caller-id enable
voice-port 0/1/2
shutdown
description Configured by CCA 4 FXO-0/1/2-Custom-AA-OP
caller-id enable
voice-port 0/1/3
shutdown
description Configured by CCA 4 FXO-0/1/3-Custom-AA-OP
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 299
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session target sip-server
incoming called-number .%
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
corlist outgoing call-local
description ** star code to SIP trunk (Generic SIP Trunk Provider) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 78 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-7-digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 8911
forward-digits all
no sip-register
dial-peer voice 79 pots
trunkgroup ALL_FXO
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 80 pots
trunkgroup ALL_FXO
description **CCA*North American-7-digit*7-Digit Local**
preference 5
destination-pattern 8[2-9]......
forward-digits all
no sip-register
dial-peer voice 81 pots
trunkgroup ALL_FXO
description **CCA*North American-7-digit*Service Numbers**
preference 5
destination-pattern 8[2-9]11
forward-digits all
no sip-register
dial-peer voice 82 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-7-digit*Long Distance**
preference 5
destination-pattern 81[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 83 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-7-digit*International**
preference 5
destination-pattern 8011T
forward-digits all
no sip-register
dial-peer voice 84 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-7-digit*Toll-Free**
preference 5
destination-pattern 81800.......
forward-digits all
no sip-register
dial-peer voice 85 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 81888.......
forward-digits all
no sip-register
dial-peer voice 86 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 81877.......
forward-digits all
no sip-register
dial-peer voice 87 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 81866.......
forward-digits all
no sip-register
dial-peer voice 1040 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1041 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1042 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1043 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1044 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1045 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1046 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1047 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1048 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1049 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2010 voip
description dial-peer for prompt management
destination-pattern 410
b2bua
codec g711ulaw
no vad
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
direct-inward-dial
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 400
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3000 voip
description KTP-BG
translation-profile incoming KTP-BG_Called_4
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3001 voip
description InboundDirect-BG
translation-profile incoming InboundDirect-BG_Called_5
voice-class codec 1
incoming called-number 1"mynumberishere"
dtmf-relay rtp-nte
no vad
no dial-peer outbound status-check pots
sip-ua
authentication username <removed> password 7 <removed>
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:66.23.129.253:5060 expires 3600
sip-server ipv4:66.23.129.253:5060
  host-registrar
telephony-service
video
fxo hook-flash
load 7914 S00105000300
load 7915-12 B015-1-0-3
load 7915-24 B015-1-0-3
load 7916-12 B016-1-0-3
load 7916-24 B016-1-0-3
load 7906 SCCP11.8-4-2S
load 7911 SCCP11.8-4-2S
load 7921 CP7921G-1.2.1
load 7925 CP7925G-1.3.1
load 7931 SCCP31.8-4-2S
load 7936 cmterm_7936.3-3-16-0
load 7937 apps37sccp.1-3-2-0
load 7960-7940 P00308001000
load 7941 SCCP41.8-4-2S
load 7941GE SCCP41.8-4-2S
load 7942 SCCP42.8-4-2S
load 7945 SCCP45.8-4-2S
load 7961 SCCP41.8-4-2S
load 7961GE SCCP41.8-4-2S
load 7962 SCCP42.8-4-2S
load 7965 SCCP45.8-4-2S
load 7970 SCCP70.8-4-2S
load 7971 SCCP70.8-4-2S
load 7975 SCCP75.8-4-2S
load 521G-524G cp524g-8-1-16b
load 525G spa525g-7-1-9
max-ephones 22
max-dn 88
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone SPA525-Encryption-key B7dcuyGmbbSayblucfky
service phone SPA525-wifi-on yes
service phone SPA525-protocol SPCP
service phone SPA525-auto-detect-sccp yes
service phone SPA525-http-write yes
service phone SPA525-SSID uc520-voice
service phone SPA525-readonly no
service phone SPA525-Encryption-type WPA2_PSK
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message company
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
cnf-file location flash:
time-zone 13
voicemail 299
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 8.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 8
night-service day Sun 12:00 18:00
night-service day Mon 19:00 08:00
night-service day Tue 19:00 08:00
night-service day Wed 19:00 08:00
night-service day Thu 19:00 08:00
night-service day Fri 19:00 08:00
night-service day Sat 10:00 18:00
night-service date Dec 25 00:00 23:59
night-service date Dec 26 00:00 23:59
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
banner login ^CCisco Configuration Assistant. Version: 2.1. Fri Oct 16 11:15:22 EDT 2009^C
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
line con 0
session-timeout 240
exec-timeout 60 0
no modem enable
line aux 0
session-timeout 240
exec-timeout 60 0
line 2
session-timeout 240
exec-timeout 60 0
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
session-timeout 240
exec-timeout 60 0
transport input telnet ssh
transport output telnet ssh
line vty 5 100
session-timeout 240
exec-timeout 60 0
end
Everyone's tags (6)
1 REPLY
Hall of Fame Super Gold
Reload.
That would also be a good occasion to update system, and clean up config.
689
