01-31-2012 03:27 AM - edited 03-21-2019 05:16 AM
I have new setup with UC540 with 7 SPA 525 2G phones. 4 out of 7 phones register fine and work.
3 don´t register. Phone display just gives "unregistered" the phones seem all identical.
Has anyone had intermittent issues like this with the SPA 525 2G ?
01-31-2012 11:57 AM
Did you try to do a factory reset on the phone yet?
01-31-2012 05:04 PM
Yes tried all that. I am wondering if some of the SPA 525 2G has manufacturing faults...
01-31-2012 06:47 PM
In the phone menu under call control settings, is SCCP selected?
When you look under network settings do you see 10.1.1.1 as your TFTP server?
What IP address and VLAN did the phone pull up?
02-06-2012 06:16 AM
Marcus,
Do SPA525G2 support SCCP? I thought the two signaling protocols were SPCP and SIP.
Thanks!
02-06-2012 12:59 PM
No, only SPCP and SIP. I sometimes forget SPA phones use SPCP instead of SCCP.
02-06-2012 01:09 PM
Hi Kristjan,
Make sure the MAC you put in is right on the entries in the system.
Also make sure they are listed as SPA-525G2 in either CLI or through CCA.
Both of those will also produce those errors.
Cheers,
David.
06-18-2014 07:05 AM
Please send the show run and debug ephone stat
