Community Member
UC500 FXS Port COnfiguration for digital postage meter
I am having an issue with a similar device, a digital postage meter.  I would assume that it operates similar to a credit card machine.  I reviewed the doc that you sited above but I still could not get the unit to connect.  I am not sure of the proper debug's and or the information that I am looking for in the debugs.  Any assistance would be appreciated.
Cheers,
Mike
Re: UC500 FXS Port COnfiguration for digital postage meter
Yes, this is a similar issue to the first thread.  Probably the first thing to do is check with your SIP service provider to see if they have modem passthrough enabled in their network.  If they don't have it setup at their end, then there is not much you can do.  The best you can do is force the use of an uncompressed codec (ie g711) and see how it goes.
The alternative if you have any analog or digital PSTN line connected to your system is to configure an extra pattern in the Outgoing dial plan that forces calls from the postage meter out the PSTN line, thus bypassing the VoIP trunk.
If you want to do detailed debugging of this, I'd suggest you log a TAC case and get an engineer on the phone to work this through with you.  Unfortunately, in the absence of modem passthrough or relay, supporting modem connections over VoIP is always tricky.
Cheers,
Dave.
Community Member
Thats actually a good thought.  I am not using a SIP provider but a full PRI (23channel) and no extra PSTN circuits.  I informed XO that the number in question was fax.  I will check to verify if there is anything they need to address on there side for this.  The fax works just fine it's this stupid postal machine that is causing all this BS.
Cheers
If it is an ISDN service, then we are on much more solid ground.  Couple of things to look for:
- In CCA, look at Monitor > Reports > T1/E1/BRI Status and have a look and see if you are getting any errors at the physical or framing level.  If the counters to look at aren't obvious (and they are not really), grab a couple of snapshots separated in time by several minutes and post them here and we can have a look.
- If you are comfortable telneting to the UC500 and using the command line, can you capture the output of 'show network-clocks'?  I don't expect to see anything here other than confirmation that clocking is set up properly, but it is good to double check.
Cheers,
Dave.
Community Member
Here is a cut of the show network-clocking
  Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          T1 0/2/0        GOOD            T1
     7          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          T1 0/2/0        GOOD            T1
I am not familiar with the CCA.  I ususally use the CLI and CUE GUI for all my config's.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
modem passthrough nse payload-type 101 codec g711ulaw maximum-sessions 1
sip
  no update-callerid
Ok, the clock is being sourced correctly.  Can you post the output from 'show controller t1 0/2/0' - preferably two sets of output taken several minutes apart.  What I'm looking for is to see if there are any errors on the line, since a low error rate will not be noticeable on voice calls but can definitely cause modem problems.
By the way, whereabouts are you located using a T1?  We don't really use T1's in Australia or New Zealand.
Cheers,
Dave.
Community Member
Well you asked for it well you got it
T1 0/2/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20080918, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (54 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
  Data in Interval 2:
  Data in Interval 3:
  Data in Interval 4:
  Data in Interval 5:
  Data in Interval 6:
  Data in Interval 7:
  Data in Interval 8:
  Data in Interval 9:
  Data in Interval 10:
  Data in Interval 11:
  Data in Interval 12:
  Data in Interval 13:
  Data in Interval 14:
  Data in Interval 15:
  Data in Interval 16:
  Data in Interval 17:
  Data in Interval 18:
  Data in Interval 19:
  Data in Interval 20:
  Data in Interval 21:
  Data in Interval 22:
  Data in Interval 23:
  Data in Interval 24:
  Data in Interval 25:
  Data in Interval 26:
  Data in Interval 27:
  Data in Interval 28:
  Data in Interval 29:
  Data in Interval 30:
  Data in Interval 31:
  Data in Interval 32:
  Data in Interval 33:
  Data in Interval 34:
  Data in Interval 35:
  Data in Interval 36:
  Data in Interval 37:
  Data in Interval 38:
  Data in Interval 39:
  Data in Interval 40:
  Data in Interval 41:
  Data in Interval 42:
  Data in Interval 43:
  Data in Interval 44:
  Data in Interval 45:
  Data in Interval 46:
  Data in Interval 47:
  Data in Interval 48:
  Data in Interval 49:
  Data in Interval 50:
  Data in Interval 51:
  Data in Interval 52:
  Data in Interval 53:
  Data in Interval 54:
  Data in Interval 55:
  Data in Interval 56:
  Data in Interval 57:
  Data in Interval 58:
  Data in Interval 59:
  Data in Interval 60:
  Data in Interval 61:
  Data in Interval 62:
  Data in Interval 63:
  Data in Interval 64:
  Data in Interval 65:
  Data in Interval 66:
  Data in Interval 67:
  Data in Interval 68:
  Data in Interval 69:
  Data in Interval 70:
  Data in Interval 71:
  Data in Interval 72:
  Data in Interval 73:
  Data in Interval 74:
  Data in Interval 75:
  Data in Interval 76:
  Data in Interval 77:
  Data in Interval 78:
  Data in Interval 79:
  Data in Interval 80:
  Data in Interval 81:
  Data in Interval 82:
  Data in Interval 83:
  Data in Interval 84:
  Data in Interval 85:
  Data in Interval 86:
  Data in Interval 87:
  Data in Interval 88:
  Data in Interval 89:
  Data in Interval 90:
  Data in Interval 91:
  Data in Interval 92:
  Data in Interval 93:
  Data in Interval 94:
  Data in Interval 95:
  Data in Interval 96:
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
I didnt see much in the out put but take a look.  I am in the good old USA.  Lots of T1's and DS3's.
Ok, that's all clean.
So a couple of obvious questions I should have asked earlier:
- Does the meter work if plugged into a regular telephone line straight from the telco? (I assume so, but you never know)
- Also, what do you see when you try to make a call?  Does the remote end answer and then the call drops, or does it never answer?
Cheers,
Dave.
Community Member
yes the unit works on a regular PSTN line.  I was going to put a butt set on the line to see what the unit was dialing.  I am going to contact XO to make sure they are not messing with the signaling and then may be a TAC call.
The other possibility is to make sure you are not running afoul of the unit just dialing the number without having an outside access code specified.  It would also be worth plugging the tester in between the meter and the UC500 and just listening to see how far the call progresses - ie, offhook, dial tone, dialing, ring back, answer, modem tones etc.  If the connection is failing in this path somewhere, then we can dig into it further, as that will give us some clues.  If the connection is faling during modem training or during data transfer then it gets harder.  There are a couple of possibilities that spring to mind such as mismatched line impedence on the analog connection between the meter and the UC500, or audio distortion due to incorrect gain settings, but I would expect you would hear audible symptoms on normal voice calls then as well.
Cheers,
Dave.
Community Member
Well that though actually crossed my mind but the fax machine is attached to the same line and it does not require a outside access digit, in their case an '8'.  I think that I am going to place a monitor inline and see what the unit is putting out.  The kicker is the fax that operates on the same FXS port works just fine inbound and outbound.  If you have some suggestions on the impedence and audio, I am all ears.
-mike
If the fax is working on the same port, then that suggests that the levels and so forth are probably correct, though it is always possible that the postage meter has an incorrect impedence setting for example.  But again, that's pretty far fetched.  I'll be interested to see what you get from monitoring the line.
Cheers,
Dave.
Community Member
Well just a little update.  I have been working with TAC a very nice fellow name Berry in NC.  We have found that the postal device is dialing 1800 (other digits are not relitive to this issue).  We were performing some dumps and debugs and found that the UC is only seeing 180xxxxxxx.  The 00 are being interpriated as 0.  We decieded to do a incoming translation of /180xxxxxxx/ /1800xxxxxxx/.  Please not the real digits have been replaced with x's.  So I hope to have a test done on Monday and I will post the final results and a bit more info.
Cheers
It sounds like the gap between the dialed digits is not large enough for the UC500 to reliably detect it, so the two zeros are detected as a signle digit.  I'm guessing there are not patterns of two or more identical digits in succession in the rest of the number so that this is the only place it gets missed.  One thing you could try is to look and see if there is a setting on the postage meter that controls the speed at which it dials or even that controls the gap between the digits.
Otherwise we might need to capture an audio trace of the meter dialing and see if we can do anything to tune the UC500 to match what the meter is doing.
Cheers,
Dave.
Community Member
Well, the issue has been resolved.  Yes you would be correct about the digit timing.  The issue was that when the unit went to dial, 1800xxxxxxx.  The clients AA is 180.  So you might guess where this is going.  Basically when the unit was attempting to dial out and it was just getting the AA.  I have no way to instruct the meter to dial an "8" for outside number prefix.  TAC and I tried a few different translation rules and prefix's.  We decided to change the extension number of the AA and VM.  Issue was resolved.  The lesson here, watch what your extesion plans are, use 4 digits or more and dont let the client beat you into make 3 digit extensions.
Cheers.
Ok, that is not uncommon.  There is a way you can use the CLI to prefix the dialed number with an access code which would also solve the problem, but it can get a little complicated depending on how the box has been set up.
Anyway, glad to hear you got to the bottom of it.
Cheers,
Dave.
6133
