UC500 integration with Skype
I got this question from one of our partners in Kazakhstan.
Is it possible to create a common corporate SkypeID that will be used as one of the lines of communications with clients, i.e. example, button on a Skype to call  from skype, when it is pressed the client's Skype calls  Syp ID of the company and UC500  in its turn processes such calls. And to tune on  UC500 to use Skype as the main operator for incoming international calls.
Any help will be greatly appreciated... Thanks!
2 ACCEPTED SOLUTIONS
Re: UC500 integration with Skype
Yes.  Google for "Skype for SIP"
With Skype for SIP you should be able to easily configure a "click to call" button on a web page for example that rings into your UC500 system.  You can also call out over Skype account.
Brandon
-- please remember to rate and mark answered helpful posts --
Bronze
From early last year:
https://supportforums.cisco.com/docs/DOC-9428
HTH,
Andrew Lissitz
Brandon
Bronze
HTH,
Andrew Lissitz
Thanks for all the help.
Bronze
You are most welcome.  If you find the time, we would love to hear how it goes and learn from you as you proceed.
Take care,
Andrew Lissitz
916
