Hi Shaurya,
Darren is correct, placing everything on the root of the flash card is just Insane and asking for problems, the directory structure is in place for a reason and its not just for cleanliness either
If you are not using CCA as Darren has suggested, loading TFTP commands is no harder then if it was on the root directory, the only differences is that you need to use the alias command now rather then back in the old days it was just a straight point to file, an example of how this would look is:
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
The most easiest way to manage this is to work up the TFTP-SERVER configuration in a txt editor and then just do a CLI dump, although this can sometimes generate errors so if you have never done it then it is best to do it no more than 3 lines at a time.
But in any event you should be using CCA to both build and manage the system, its just one of those things that you might not like, but in the end you learn to appreciate it
Cheers,
David.
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
