07-28-2009 08:57 AM - last edited on 03-25-2019 10:40 PM by ciscomoderator
I searched this site, UC500.com, and cisco for any installation guides setting up a Qwest PRI circuit on the UC500, and specifically on the VWIC2-1MFT-T1/E1=
We're always doing Cbeyond SIP circuits and now we have a Qwest PRI circuit.
Does anyone have the set up guide/seps /procedure for this card on the UC500 ?
I'd love any guides, advice, look out for these gotchas, etc
Thanks!
Stacy
Solved! Go to Solution.
07-28-2009 08:59 AM
Hi Stacy,
I´ve found that the setup is easy using CCA. The one thing I ended up struggling with was a CRC setting from the telco. Other than that it was "a walk in the park" (is that the correct term?!
)Regards
Eivind
You can take a look at my post when I setup my first UC with a VWIC card;
https://www.myciscocommunity.com/message/8911
Message was edited by: Eivind Jonassen
07-28-2009 09:36 AM
07-28-2009 08:59 AM
Hi Stacy,
)Regards
Eivind
07-28-2009 09:36 AM
Stacy,
Eivind is correct. CCA should get you there.
Marcos
07-28-2009 10:41 AM
Thank you for your help !!
