Community Member
UC500
Would like to connect up our 3rd party cti software to a clients UC500 - however local supplier is very vague on what interface is needed on the UC500 to
enable this. Any advices on what is required are appreciated.
Everyone's tags (1)
1 REPLY
Community Member
Re: UC500
Hi Trevor,
Couple of questions
1. What is the CTI 3rd party software you want to integrate into the UC-500?
2. Have you looked at Call Connector as a possible solution which is provided by Cisco?
3. What type of CTI integration are wanting to achieve? I.E what is you really want to do??
The more you can tell us the easier it is to answer and also try and give you the best answer, i understand that the vendor is being vague with you, but you need to try and not be vague with us otherwise we are flying just as blind as you are and most likely cant help you out properly.
Hope you can give us some answers to the questions above.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
484
