Community Member
UC520 - Inbound calls get terminated at voicemail prompt
I can make inbound calls, outbound calls, call from one extension to another extension and leave voicemail at the extension.
Inbound call to SIP DID which is configured as secondary number of an extension --> no answer call forward to voicemail pilot # 500 --> hear personal greeting of voicemail box I am supposed to leave voice mail, then voicemail prompt '...... when you are finished, hang up..'. Calls get terminated at nearly the same point of the prompt every time. Error message from debug ... "cc_api_call_disconnected:Cause Value=102" and "Reason: Q.850;cause=86".
IOS Version 15.0(1)XA3a; CUE 8.0.2; CCA 2.2.5
Would this be a timer issue or something else ? Thanks.
1 REPLY
Re: UC520 - Inbound calls get terminated at voicemail prompt
The issue is that this 200 OK is not being ACKed:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP aaa.bb.cc.40;branch=z9hG4bKfee8.d4965f1.0,SIP/2.0/UDP ddd.ee.fff.101:5060;received=ddd.ee.fff.101;rport=5060;branch=z9hG4bK-10765d90087576b04c489974689f47e7-ddd.ee.fff.101-1
From: "Anonymous" ;tag=ddd.ee.fff.101+1+3adf4e+dffad19e
To: <1234567890>;tag=B9D3DD8-1442
Date: Sun, 26 Sep 2010 18:32:24 GMT
Call-ID: 4CE9030C@ddd.ee.fff.101
CSeq: 64166520 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Contact: <1234567890>
Record-Route: ,
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 219
v=0
o=CiscoSystemsSIP-GW-UserAgent 0 8513 IN IP4 10.198.16.1
s=SIP Call
t=0 0
m=audio 16848 RTP/AVP 0 101
c=IN IP4 10.198.16.1
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
You will need to investigate this from the device that this 200 OK is being sent to, to find out a) if they receive this 200 OK and b) why they aren't sending an ACK for it.
272
