Community Member
uc520 outbound call to auto-answering systems
We just installed a UC520 system to one of our clients and they have a problem when calling anybody that has an automated attendant. When the called party auto attendant asks you to enter a number to select an option, the option is not being selected. I advised client to try use # or * before the number but still won't work. Can you please advise? Client is using SIP trunk.
Community Member
Re: uc520 outbound call to auto-answering systems
Hello Spitm012,
We have moved your question from the Collaborations Partner Community to this more technically focused Small Business Support Community as you will have a better chance of finding a technical resolution here.
Thank You,
Cisco Moderation Team
Community Member
There is information in this thread that may help you
https://www.myciscocommunity.com/message/3274#3274
basically you need to match the dtmf-relay configuration in your outbound dial-peers to what your SIP provider supports.
3323
