Community Member
UC520 SIP Incoming OK Outgoing Fail
Hi I've a UC520 and im tring to connect to a Voip Supplier "Engin"
it is regestering
and i can recieve calls but i cannot make any calls
the debug logs shows disconnect (47) "No Resouces"
i'm complealy stumped
i've attached a copy of the incoming and outgoing log and a show tech
Leslie
Everyone's tags (2)
Hello Leslie,
I would try to remove the keepalive target and the keepalive time and re register with the SIP provider.
under sip-ua:
no keepalive taget
no timers keepalive
HTH,
Alex
*Please rate helpful posts
Community Member
Found the outgoing SIP calls
Found the outgoing SIP calls where not being resolved though DNS properly
it looks like it has resolved correctly in the log
003450: Mar  5 06:02:59.103: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: IP Address of vic-vsbc.byo.engin.com.au is:
003451: Mar  5 06:02:59.103: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: 203.161.164.69
but we had to change
outbound-proxy dns:byo.engin.com.au
to
outbound-proxy ipv4:203.161.164.69:5060
Community Member
159
