12-22-2011 02:11 PM - edited 03-21-2019 05:06 AM
Good Afternoon Everyone,
I'm experiencing a strange issue when trying to restore the backups made prior to the upgrade to 8.2 from 7.x .. Most of the configuration made it across, but the Auto-Attendant, voicemails, and scripts didn't make it over. I'm guessing it has something to do with the error I get when trying to restore from the backup.
Below is a snapshot of the logs during the "Restore" from backup. At the very end is the place where it gets ERROR messages that I believe is trying to use CCA ftp server.
Can anyone point me in the right direction?
Thank you,
Kyle
Server ready :: Apache FTP Server
13:51:22,511 [ERROR] [INFO] FtpServer - ------- Apache FTP Server started ------
13:51:22,589 [DEBUG] MCEBUBackupRestore:patch
13:51:22,589 [DEBUG] C:\Users\KYLE\.configuration assistant\UC520_0024.1424.60c0_UC520-24U-8FXO-K9_config-archive_1324522727178\UC520_0024.1424.60c0_UC520-24U-8FXO-K9_startup-config_1324522727178
13:51:24,102 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/show/license/CR
13:51:25,639 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/show/license/CR
13:51:25,655 [DEBUG] It took 3066 msec
13:51:25,670 [INFO ] https://192.168.101.8:443/ deviceIsTftpReachable got request
13:51:25,670 [INFO ] TftpAddressMgrImplementation:TestCoordinator(): ip = 192.168.101.118
13:51:25,826 [INFO ] TftpAddressMgrImplementation:TestCoordinator(): ip = 192.168.101.125
13:51:25,982 [INFO ] TftpAddressMgrImplementation:TestCoordinator(): Filtered IPV6 Address = fe80:0:0:0:8ced:113d:f3ec:3954
13:51:25,982 [INFO ] TftpAddressMgrImplementation:TestCoordinator(): Filtered IPV6 Address = fe80:0:0:0:5896:e251:9f0:b6ae
13:51:26,762 [INFO ] TftpAddressMgrImplementation:TestRequestGenerator(): receivedRequest id = test712872774781528134013245906856707658453179852065793
13:51:26,762 [INFO ] TftpAddressMgrImplementation:TestRequestGenerator(): connectedAddress = 192.168.101.118
13:51:26,762 [INFO ] https://192.168.101.8:443/ deviceIsTftpReachable returning currently tested address: 192.168.101.118
13:51:26,762 [INFO ] TftpAddressMgrImplementation:TestCoordinator(): Done testing.
13:51:26,762 [DEBUG] serverIp is: 192.168.101.118
13:51:26,950 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/test712872774781528134013245906856707658453179852065793/test712872774781528134013245906856707658453179852065793/CR
13:51:27,106 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.125\/test53179139321382740691324590685826-8002647696263146397/test53179139321382740691324590685826-8002647696263146397/CR
13:51:28,057 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181373557/startup-config/CR
13:51:33,034 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181383448/vlan.dat/CR
13:51:34,500 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/delete/\/force/\/recursive/speeddial.xml/CR
13:51:38,509 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/delete/\/force/\/recursive/bacdprompts/CR
13:51:40,054 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/mkdir/bacdprompts/CR
13:51:40,069 [DEBUG] createDirOnFlash - executeCLI result[0]: Create directory filename [bacdprompts]?
Created dir flash:bacdprompts
13:51:41,364 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181400141/bacdprompts\/en_bacd_allagentsbusy.au/CR
13:51:44,593 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181406632/bacdprompts\/en_bacd_disconnect.au/CR
13:51:47,854 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181413123/bacdprompts\/en_bacd_enter_dest.au/CR
13:51:50,943 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181419302/bacdprompts\/en_bacd_invalidoption.au/CR
13:51:53,844 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181425137/bacdprompts\/en_bacd_music_on_hold.au/CR
13:51:58,711 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181434842/bacdprompts\/en_bacd_options_menu.au/CR
13:52:02,533 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181442487/bacdprompts\/en_bacd_welcome.au/CR
13:52:05,575 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181448572/bacdprompts\/en_bacd_xferto_operator.au/CR
13:52:08,321 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/delete/\/force/\/recursive/media/CR
13:52:15,528 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/delete/\/force/\/recursive/Desktops/CR
13:52:17,073 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/mkdir/Desktops/CR
13:52:17,073 [DEBUG] createDirOnFlash - executeCLI result[0]: Create directory filename [Desktops]?
Created dir flash:Desktops
13:52:18,539 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/mkdir/Desktops\/320x212x12/CR
13:52:18,539 [DEBUG] createDirOnFlash - executeCLI result[0]: Create directory filename [Desktops/320x212x12]?
Created dir flash:Desktops/320x212x12
13:52:19,834 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181477089/Desktops\/320x212x12\/List.xml/CR
13:52:21,659 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/mkdir/Desktops\/320x212x16/CR
13:52:21,659 [DEBUG] createDirOnFlash - executeCLI result[0]: Create directory filename [Desktops/320x212x16]?
Created dir flash:Desktops/320x212x16
13:52:22,954 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181483362/Desktops\/320x212x16\/List.xml/CR
13:52:24,701 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/mkdir/Desktops\/320x216x16/CR
13:52:24,701 [DEBUG] createDirOnFlash - executeCLI result[0]: Create directory filename [Desktops/320x216x16]?
Created dir flash:Desktops/320x216x16
13:52:25,996 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181489415/Desktops\/320x216x16\/List.xml/CR
13:52:27,665 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181492786/Desktops\/CampusNight.png/CR
13:52:31,253 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181499931/Desktops\/CiscoFountain.png/CR
13:52:34,388 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181506204/Desktops\/CiscoLogo.png/CR
13:52:37,196 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181511851/Desktops\/Fountain.png/CR
13:52:40,847 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181519122/Desktops\/MorroRock.png/CR
13:52:44,404 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181526205/Desktops\/NantucketFlowers.png/CR
13:52:47,773 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181532976/Desktops\/TN-CampusNight.png/CR
13:52:50,644 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181538719/Desktops\/TN-CiscoFountain.png/CR
13:52:53,436 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181544336/Desktops\/TN-CiscoLogo.png/CR
13:52:56,275 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181549985/Desktops\/TN-Fountain.png/CR
13:52:59,146 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181555726/Desktops\/TN-MorroRock.png/CR
13:53:02,016 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181561467/Desktops\/TN-NantucketFlowers.png/CR
13:53:15,760 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/delete/\/force/\/recursive/ringtones/CR
13:53:17,304 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/mkdir/ringtones/CR
13:53:17,304 [DEBUG] createDirOnFlash - executeCLI result[0]: Create directory filename [ringtones]?
Created dir flash:ringtones
13:53:18,599 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181594634/ringtones\/Analog1.raw/CR
13:53:21,360 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181600127/ringtones\/Analog2.raw/CR
13:53:23,997 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181605462/ringtones\/AreYouThere.raw/CR
13:53:26,633 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181610737/ringtones\/AreYouThereF.raw/CR
13:53:29,316 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181616042/ringtones\/Bass.raw/CR
13:53:31,953 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181621409/ringtones\/CallBack.raw/CR
13:53:34,776 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181627026/ringtones\/Chime.raw/CR
13:53:37,522 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181632487/ringtones\/Classic1.raw/CR
13:53:40,236 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181637948/ringtones\/Classic2.raw/CR
13:53:42,997 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181643441/ringtones\/ClockShop.raw/CR
13:53:45,727 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181648902/ringtones\/DistinctiveRingList.xml/CR
13:53:48,426 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181654299/ringtones\/Drums1.raw/CR
13:53:51,156 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181659760/ringtones\/Drums2.raw/CR
13:53:54,027 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181665471/ringtones\/FilmScore.raw/CR
13:53:56,710 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181670870/ringtones\/HarpSynth.raw/CR
13:53:59,377 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181676237/ringtones\/Jamaica.raw/CR
13:54:02,031 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181681552/ringtones\/KotoEffect.raw/CR
13:54:04,792 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181687037/ringtones\/MusicBox.raw/CR
13:54:07,553 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181692560/ringtones\/Piano1.raw/CR
13:54:10,268 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181697991/ringtones\/Piano2.raw/CR
13:54:13,013 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181703514/ringtones\/Pop.raw/CR
13:54:15,837 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181709131/ringtones\/Pulse1.raw/CR
13:54:18,598 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181714624/ringtones\/Ring1.raw/CR
13:54:21,250 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181719959/ringtones\/Ring2.raw/CR
13:54:23,949 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181725358/ringtones\/Ring3.raw/CR
13:54:26,648 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181730787/ringtones\/Ring4.raw/CR
13:54:29,300 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181736062/ringtones\/Ring5.raw/CR
13:54:31,936 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181741335/ringtones\/Ring6.raw/CR
13:54:34,572 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181746640/ringtones\/Ring7.raw/CR
13:54:37,427 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181752319/ringtones\/RingList.xml/CR
13:54:40,142 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181757750/ringtones\/Sax1.raw/CR
13:54:42,887 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181763241/ringtones\/Sax2.raw/CR
13:54:45,695 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/2649181768858/ringtones\/Vibe.raw/CR
13:54:48,316 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/delete/\/force/\/recursive/applications/CR
13:54:49,392 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/delete/\/force/\/recursive/English_United_States/CR
13:54:50,578 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/delete/\/force/\/recursive/its/CR
13:54:50,578 [INFO ] https://192.168.101.8:443/ deviceIsTftpReachable got request
13:54:50,578 [INFO ] TftpAddressMgrImplementation:TestCoordinator(): ip = 192.168.101.118
13:54:51,654 [INFO ] TftpAddressMgrImplementation:TestRequestGenerator(): receivedRequest id = test-23264010518222905171324590890578-8639693867999207748
13:54:51,654 [INFO ] TftpAddressMgrImplementation:TestRequestGenerator(): connectedAddress = 192.168.101.118
13:54:51,654 [INFO ] https://192.168.101.8:443/ deviceIsTftpReachable returning currently tested address: 192.168.101.118
13:54:51,857 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/test-23264010518222905171324590890578-8639693867999207748/test-23264010518222905171324590890578-8639693867999207748/CR
13:54:52,668 [ERROR] createFtpUserAcct(): failed to create username = cisco passwd = cisco rootDir = C:\Users\KYLE\.configuration assistant\backups\cue
13:54:52,668 [ERROR] java.lang.IllegalArgumentException: Directory for user does not exist
13:54:52,668 [ERROR] at com.cisco.cpnm.frmwrk.net.ftp.FtpServiceManager.createUser(FtpServiceManager.java:405)
13:54:52,668 [ERROR] at com.cisco.cpnm.features.mcebu.defn.backrest.MCEBUArchiveConfiguration.createFtpUserAcct(MCEBUArchiveConfiguration.java:92)
13:54:52,668 [ERROR] at com.cisco.cpnm.features.mcebu.defn.backrest.MCEBUArchiveConfiguration.setupFtp(MCEBUArchiveConfiguration.java:163)
13:54:52,668 [ERROR] at com.cisco.cpnm.features.mcebu.defn.backrest.MCEBUArchiveConfiguration.doCueRestore(MCEBUArchiveConfiguration.java:406)
13:54:52,668 [ERROR] at com.cisco.cpnm.features.mcebu.defn.backrest.MCEBUArchiveConfiguration.conductModuleRestore(MCEBUArchiveConfiguration.java:367)
13:54:52,668 [ERROR] at com.cisco.cpnm.features.defn.backrest.CommonArchiveConfiguration.conductRestore(CommonArchiveConfiguration.java:192)
13:54:52,668 [ERROR] at com.cisco.cpnm.features.defn.backrest.CommonArchiveConfiguration.conductRestore(CommonArchiveConfiguration.java:205)
13:54:52,668 [ERROR] at com.cisco.cpnm.features.defn.backrest.BackupRestoreConfigTask$RestoreWorkerThread.run(BackupRestoreConfigTask.java:1413)
13:54:52,668 [ERROR] at com.cisco.cpnm.frmwrk.gen.util.ThreadPool$WorkerThread.run(ThreadPool.java:1010)
13:54:52,668 [ERROR] setupFtp(): failed to create user account
13:54:52,668 [ERROR] doCueRestore() failed to start FTP Service
13:54:52,668 [ERROR] com.cisco.cpnm.legacy.device.CLIException: <html><body>Cannot start the CCA embedded TFTP or FTP service.<br>Disable any third-party TFTP or FTP services running on this PC.<br>If there are no third-party TFTP or FTP services running,<br>check the firewall and network security settings on your PC<br>to make sure that TFTP or FTP packets can be transmitted<br>between this PC and Cisco devices in the customer site.<br>If the problem persists, try restarting the PC to release<br>TFTP or FTP ports that might still be in use from a prior CCA session<br><b>or other third-party servers.</b></body></html>
13:54:52,668 [ERROR] at com.cisco.cpnm.features.mcebu.defn.backrest.MCEBUArchiveConfiguration.doCueRestore(MCEBUArchiveConfiguration.java:410)
13:54:52,668 [DEBUG] Finished with the restore thread for : UC520
12-22-2011 03:33 PM
To add some additional information.
The troubleshooting steps I've taken so far:
No FTP / TFTP servers running on this computer (or another machine I tested) netstat -a before launching CCA
Firewalls disabled
Antivirus disabled
Disabled all except one NIC (Even disabled IPv6 as a troubleshooting step)
Can ping 192.168.101.8 and 10.1.1.1
Also, to show that the FTP works, just fails on that step, I uploaded a script file from an old backup and watched the logs again:
15:30:03,581 [ERROR] [INFO] FtpServer - ------- Apache FTP Server started ------
15:30:03,799 [INFO ] https://192.168.101.8:443/ deviceIsTftpReachable got request
15:30:03,799 [INFO ] TftpAddressMgrImplementation:TestCoordinator(): ip = 192.168.101.118
15:30:04,876 [INFO ] TftpAddressMgrImplementation:TestRequestGenerator(): receivedRequest id = test-887186967230949790413245966037996321392039763755795
15:30:04,876 [INFO ] TftpAddressMgrImplementation:TestRequestGenerator(): connectedAddress = 192.168.101.118
15:30:04,876 [INFO ] https://192.168.101.8:443/ deviceIsTftpReachable returning currently tested address: 192.168.101.118
15:30:04,876 [DEBUG] In getFtpUrlForFile, Calling reconfigureFtpServer
15:30:04,876 [DEBUG] In reconfigureFtpServer, Setting passive.address on the ftp server: 192.168.101.118
15:30:04,876 [ERROR] [INFO] FtpServer - ------- Apache FTP Server started ------
15:30:04,876 [INFO ] Checking CUE connectivity
15:30:04,876 [DEBUG] ConsoleIOSCmdService: checkConnect
15:30:04,876 [DEBUG] ConsoleIOSCmdService: sending "\r\n"
15:30:04,876 [DEBUG] ConsoleIOSCmdService: expecting ">"
15:30:04,891 [DEBUG] ConsoleIOSCmdService: sending "\r\n"
15:30:04,927 [DEBUG] ConsoleIOSCmdService: sending "\r\n"
15:30:04,962 [DEBUG] ConsoleIOSCmdService: sending "\r\n"
15:30:04,997 [DEBUG] ConsoleIOSCmdService: checkConnect
15:30:04,998 [DEBUG] ConsoleIOSCmdService: sending "\r\n"
15:30:04,999 [DEBUG] ConsoleIOSCmdService: expecting ">"
15:30:05,014 [DEBUG] ConsoleIOSCmdService: sending "ccn copy url ftp://192.168.101.118/AA_SBCS_v01.aef script AA_SBCS_v01.aef username testuser password testuser\r\n"
15:30:05,077 [CLI ] CLIEngine: Executed: https://192.168.101.8/exec/copy/tftp:\/\/192.168.101.118\/test-887186967230949790413245966037996321392039763755795/test-887186967230949790413245966037996321392039763755795/CR
15:30:11,722 [DEBUG] ConsoleIOSCmdService: expecting ">"
15:30:11,863 [ERROR] [INFO] RequestHandler - Open connection - 192.168.101.9
15:30:11,863 [ERROR] [INFO] PASS - Login success - testuser
15:30:11,863 [ERROR] [INFO] RequestHandler - Close connection : 192.168.101.9 - testuser
15:30:11,925 [ERROR] [INFO] RequestHandler - Open connection - 192.168.101.9
15:30:11,925 [ERROR] [INFO] PASS - Login success - testuser
15:30:11,941 [ERROR] [INFO] RETR - File download : testuser - /AA_SBCS_v01.aef
15:30:11,972 [ERROR] [INFO] RequestHandler - Close connection : 192.168.101.9 - testuser
Socket timeout occurred: 1
Socket timeout occurred: 2
Socket timeout occurred: 3
15:30:31,737 [DEBUG]
12-22-2011 04:09 PM
Another update on my side.
In following the error message below:
13:54:52,668 [ERROR] createFtpUserAcct(): failed to create username = cisco passwd = cisco rootDir = C:\Users\KYLE\.configuration assistant\backups\cue 13:54:52,668 [ERROR] java.lang.IllegalArgumentException: Directory for user does not exist
I created the "cue" folder in the backup folder.
It went through a lot farther than before, but now I'm still having some other issues with restoring. I will see what I can figure out.
12-22-2011 08:29 PM
Hi Kyle,
Your biggest problem is that upgrading from version 7.X.X to version 8.X is a very large leap and the scripts may not import properly or even at all, I actually think this is what you are experiencing. I am not aware of anyone who has had a great deal of success doing a large upgrade like that, the only time it has worked without major issue is if you do a staged-stepped-update which means you would have to do about 2 upgrades before you reach 8.2.
Yes a long winded and headache prone process, but some people just need to keep things the way it was before and I understand that, for me starting from scratch is by far more productive and easier
I would get support involved as I think they may have some tricks up their sleeves to get it to work, give them a call and log a case, you might need to log it under "Upgrade" or "Configuration" assistance so that way you get someone who might be more experienced with doing these things.
Cheers,
David.
12-23-2011 10:38 AM
I have given up restoring the prompts and whatnot.
We are just going to re-record the prompts and write the welcome scripts again.
90% of the configuration held, so just losing those things is not a big deal. Although some users are a little upset about losing voicemails, but most of them ignore their voicemails anyway.
I wouldn't mind starting the phone system over from factory, but we have a PRI / T1 installed, and I didn't set that up, so I don't know how to configure it.
Thank you for your reply.
I think next time we do an upgrade, I'll just tell them no.
