UC520W-8U-4FXO-K9 Licensing Upgrade
gviamonte
According to this document: https://supportforums.cisco.com/docs/DOC-9694 the max number of users on my
UC520W-8U-4FXO-K9 should be 16. Below  is the output from show tech on the device. We have 22 registered phones. We need to add 16 new phones, is that possible? Do we have to buy a new UCS? Thanks in advance.
Cisco UC520W-8U-4FXO-K9 (MPC8358) processor (revision 0x300) with 235520K/26624K bytes of memory.
Processor board ID FHK134070HJ
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
22 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
David Hornstein
Level 7
Level 7
The unit has under gone a 8 user upgrade already,  since the base unit is a UC520W-8U-4FXO.
8U stands for a base 8 User license.
So the licensing on your current unit  is ;
  • 16 user licenses
  • 4 supplimentary  users licenses for integrated FXS phones
  • 2 supplimentary  users licences for maybe IP communicator
total 22 phones  as seen on your command 'show tech'
Total phones supported on UC520 with 16 user licenses is then 22 phones.
UC520W-8U-4FX0  will not support 38 phones.
I would suggest you have a chat to your Cisco partner to take advantage of possible programs to migrate you to a UC560.
Here is a extract from the URL mentioned below as seen as table 4..
Phones supported on a UC560 platform , reference URL  ;
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/reference_guide_c07-566560.html
Table 4. Licensing and User Capacity for the Cisco UC 560
License Configuration
Description
UC560 (FXO, BRI, or T1E1 model) and 1 x L-UC-PRO-8U=
32 user licenses, 8 supplemental user licenses
UC560 (FXO, BRI, or T1E1 model) and 2 x L-UC-PRO-8U=
40 user licenses, 8 supplemental user licenses
So,  you can upgrade to a UC560 FX0 model or T1/E1 model or hopefully take advantage  of the following Technology Migration Program that was found in the following EOL announcement on the  UC520;
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/end_of_life_notice_c51-655215.html
It basically says;
Product Migration Options
Customers are encouraged to migrate to the Cisco Unified Communications 540 or 560 for Small Business. Information about these products can be found at:
http://www.cisco.com/en/US/products/ps7293/index.html
Customers can use the Cisco Technology Migration Program (TMP) to trade-in products and receive credit toward the purchase of new Cisco equipment. For more information about Cisco TMP, customers should work with their Cisco Partner or Cisco account team. Cisco Partners can find additional TMP information on Partner Central athttp://www.cisco.com/web/partners/pr11/incentive/tmp/index.html
Thanks a lot David for your response. It´s very helpful.
I think upgrading to UC560 is the rigth choice. I have a couple of additional questions: may I reuse the VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on the UC560?
The UC560 doesnt have a Wireless embeded model like my UC520W-8U-4FXO-K9. What is your recomendation regarding the WLAN feature.
Thanks in advance.
Gustavo.
