Community Member
UC540 - 7975G - UCM DOWN, FEATURES DISABLED
Using a SR520 at remote site to connect 7975G to UC540 at main site.  Keep seeing "UCM Down, Features Disabled" and the phone reboots.  Do not see this issue at the main site where the UC540 is.  Any ideas how to correct this issue?
1 REPLY
Hello, It seems that the
It seems that the phone is losing connection to the UC.
Most likely you need to check the connectivity between sites.
HTH,
Alex
95
