Community Member
UC540 Analogue trunks
Can anyone tell me how to set the UC540 so that it always picks the first line available rather than round robin or longest idle?
Mike
Everyone's tags (3)
1 REPLY
Community Member
Hello Mike,
If you are using CCA, you can adjust this setting here:
Configure > Telephony > Dial Plan > Outgoing
Choose "PSTN Trunk Group" tab, then select the trunk group for "ALL_FXO", and click "modify" at the bottom of the screen.  There you will be able to change the hunt scheme.
Thank you,
Darren
586
