Community Member
UC540 and Valcom 2001A
I am having an issue with a Cisco UC540 and Valcom paging system
We get this hooked up and it seems to work fine, but after a few hours whenever you dial an outside line the button presses go out over the paging system
Anyone have any idea what I am doing wrong with this unit.
James
Re: UC540 and Valcom 2001A
Hi James,
I have used a Valcom 9970 connected to a FXS line.
I guess the Valcom 2001A is connected to a FX0 line as the install instructions for the VALCOM 2201A shows the unit connected to a CO tip and ring.
I think the calls are routing to the Valcom when the other FX0 ports are busy.  Could this be the case  ?
Gotta use CCA to make sure that outgoing calls routing is not routed to that FX0 port.
But I must admit i prefer to use a VALCOM 9970 for single zone paging and connect it to a UC540 FXS port.
Then all I have to do is call a phone extension, like x301 to activate overhead paging.
regards Dave
Community Member
Thank you for pointing me in the right direction.
I found that the dial plan for local numbers had the page fxo port listed in it. None of the other plans had it.
780
