Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
UC540 auto attendant drops external SIP call
When a call comes into Auto Attendant and caller makes selection there is a moment of silence and the call disconnects.  This is on a SIP trunk from Vitelity.  Any option the caller chooses (transfer by name, transfer by number, etc) the call drops.  If I dial internally, everything works fine.  It is only on external calls over the SIP trunk.
Any ideas?  Thanks
Hall of Fame Super Gold
This is often asked had you searched before asking.
voice service voip
sip no supplementary-service sip moved-temporarily
sip no supplementary-service sip refer
Thank you! I tried searching and read many articles.  Guess i used the wrong key words.
Maybe you could help me on another issue:
At another site.  External SIP call comes into Auto Attendant.  It does not recognize any DTMF.  I have read this was an issue in older CCA but I am running the latest version of 8.2.
Thanks for your help.
Re: UC540 auto attendant drops external SIP call
Need dtmf-relay set properly.
I don't know anything about CCa and can't help with that.
can you point me where to find an article on how to set dtmf-relay properly?
I would suggest getting to know the IOS command line configuration method.
Using CCA inserts pages of verbose code that makes troubleshooting 100x harder.
But to answer your question, try playing with the sip service-moved temporarily option under voice service voip.
392
