01-17-2014 08:05 AM - edited 03-21-2019 08:01 AM
When a call comes in, a receptionist will transfer the caller to the appropriate extension by presing the transfer key, then the extension, then transfer again.
The caller sometimes hears Moh for a couple seconds....then will hear a dialtone as if they have been hung up on. Unfortunately, people are hanging up and calling back in. This is creating quite the problem
01-17-2014 06:41 PM
Hello.
What happens if the receptionist transfers the call and hangs up, or presses end call instead of transfer again.
Thanks.
01-17-2014 06:46 PM
Hello. Also, please post the output of "show version" from your system. Thanks.
01-23-2014 05:49 AM
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 14-Feb-13 10:17 by prod_rel_team
ROM: System Bootstrap, Version 12.4(24r)SB, RELEASE SOFTWARE (fc1)
CBI_UC540 uptime is 3 weeks, 1 day, 22 hours, 41 minutes
System restarted at 10:04:10 EST Tue Dec 31 2013
System image file is "flash:uc500-advipservicesk9-mz.151-4.M6"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco UC540W-FXO-K9 (MPC8358) processor (revision 0x100) with 235520K/26624K bytes of memory.
Processor board ID FHK14157351
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
40 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
8 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
01-23-2014 05:55 AM
They have the exact same experience
01-23-2014 08:46 AM
Hello Charlie. I see that the system has been running for 3-weeks. I would recommend saving the config and reloading the system to see if the problem persists after reboot.
