UC540 CUE Reset issues
graeme
Hi there,
I posted yesterday about problems restoring a backup to a UC540. with no response.
Since then I tried factory reseting the tet unit and CUE seems to have got hosed.
Factory Reset just sits and does nothing in CCA.
When I try to session on to UC540 CUE using
service-module integrated-service-engine 0/0 session
I get the following erroe
Trying 10.1.10.2,2002 ....closed
Connection refused by remote host
I have tried various documents about doing
service-module integrated-service-engine 0/0 reload
then immediately doing
but always get the same result
In CCA it loads voice data upto 97% and stays there for ever.
Or if I try a reset it says applying reset and stays for ever.
Any one got any suggestions
Graeme
paolo bevilacqua
Open two telnet sessions.
In one type
clear line 2 (and confirm)
You should be able to connect with that
In the other,  type
service-module integrated-service-engine 0/0 reset
Go back to first session, CUE will reset, enter *** at boot, and go from there.
Note: strongly recommend you update to 8.6.2 that is available in the latest software, check this same forum.
7 Replies 7
paolo bevilacqua
In one type
In the other,  type
graeme
hi paolo
Clear line 2002
Gives an error of invalid input at the second 0?
Graeme
Sorry I corrected my post above.
Thanks for the nice rating and good luck!
graeme
Paolo
Since entering the command I tried to session in to CUE and it worked
Now I'll try a reset thanks
graeme
hi paolo
That's what I'm trying to do
Using our test 540 restore production config to test and then upgrade.
But I got cue working and reset so thanks for your help
Graeme
I need to recover the password for UC540 because the current support company left from us. I browsed the web sites found the procedure to recover the password and it said if I do the UC540 will get factory default configuration. I want to make sure if I recover the password the current configuration will not be deleted. Please help me clear my confusion and it is very urgent.
Mostafa
Kevin Monteiro
Level 7
Level 7
Hi Mohamed,
If you do a factory reset you will loose your config.
Kevin
Sent from Cisco Technical Support Android App
