UC540 CUE Reset issues
Hi there,
I posted yesterday about problems restoring a backup to a UC540. with no response.
Since then I tried factory reseting the tet unit and CUE seems to have got hosed.
Factory Reset just sits and does nothing in CCA.
When I try to session on to UC540 CUE using
service-module integrated-service-engine 0/0 session
I get the following erroe
Trying 10.1.10.2,2002 ....closed
Connection refused by remote host
I have tried various documents about doing
service-module integrated-service-engine 0/0 reload
then immediately doing
but always get the same result
In CCA it loads voice data upto 97% and stays there for ever.
Or if I try a reset it says applying reset and stays for ever.
Any one got any suggestions
Graeme
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: UC540 CUE Reset issues
Open two telnet sessions.
In one type
clear line 2 (and confirm)
You should be able to connect with that
In the other,  type
service-module integrated-service-engine 0/0 reset
Go back to first session, CUE will reset, enter *** at boot, and go from there.
Note: strongly recommend you update to 8.6.2 that is available in the latest software, check this same forum.
In one type
In the other,  type
hi paolo
Clear line 2002
Gives an error of invalid input at the second 0?
Graeme
Sorry I corrected my post above.
Thanks for the nice rating and good luck!
Paolo
Since entering the command I tried to session in to CUE and it worked
Now I'll try a reset thanks
hi paolo
That's what I'm trying to do
Using our test 540 restore production config to test and then upgrade.
But I got cue working and reset so thanks for your help
Graeme
I need to recover the password for UC540 because the current support company left from us. I browsed the web sites found the procedure to recover the password and it said if I do the UC540 will get factory default configuration. I want to make sure if I recover the password the current configuration will not be deleted. Please help me clear my confusion and it is very urgent.
Mostafa
Re:UC540 CUE Reset issues
Hi Mohamed,
If you do a factory reset you will loose your config.
Kevin
Sent from Cisco Technical Support Android App
3191
