Community Member
UC540 expansion port
Can a Cisco SG300-28P switch be used with the expansion port on a UC540W?
3 ACCEPTED SOLUTIONS
Community Member
Yes.  The 200 and 300 series are supported via CCA also.
Community Member
Re: UC540 expansion port
Be sure to upgrade the firmware on the switch and it will work with no
problems
David Dunlap
SBSC UC Support Engineer
CCNA, SCCP SIP certified
& CCNA-Voice
10:00am to 7:00pm EST
Monday to Friday
daviddun@cisco.com
Office +1 (866) 606-1866 ext. 601050
Fax +1 (866) 875-3916
Cisco Steps to success for UC500 platform
https://supportforums.cisco.com/docs/DOC-16634
Cisco SMB support forum
https://supportforums.cisco.com/community/netpro/small-business
Cisco Technical Enablement Labs
https://supportforums.cisco.com/docs/DOC-9836
Partner CVENT Calender
4efb&t=http%3a%2f%2fwww.cvent.com%2fEVENTS%2fCalendar%2fCalendar.aspx%3fcal%
3d313c653e-5061-464b-9bc8-56ab83b20f47&s=%3cimgborder%3d%220%22src%3d%22ht
tp%3a%2f%2fcustom.cvent.com%2f7A5FE47695D247ABA545F93364B0665E%2fpix%2f49e30
e3eb8074b1bb95f4dacf65eaa42.JPG%22+alt%3d%22%22%2f%3e> Description:
Description:
http://custom.cvent.com/7A5FE47695D247ABA545F93364B0665E/pix/49e30e3eb8074b1
Community Member
Marcus Casimir wrote:
"Friends don't let friends use SIP!"
Of course they do Friends don't let Friends stay in a proprietary world, friends encourage other friends to work within an open socieity (LONG LIVE FOSS!!)
Errr back on topic
Devin make sure you upgrade your SG/SF to version 1.1.8, I have had the best success with this revision and it is the latest (Last time I looked). But here is a hint, make sure that within CCA you go to the SmartPort configuration of that switch (Right Click on it) and set all the ports up to "IP Phone+Desktop" and the ports that is plugged into the expansion port set for "Switch" and make changes to the other ports that require it to their appropriate settings.
The SF/SG series switches do not seem to accept the changes as fluid as the ESW range did, they are pretty good switches, don't get me wrong, but their interoperability with CCA/UC still seems to be a little off.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Community Member
Community Member
problems
David Dunlap
& CCNA-Voice
Monday to Friday
daviddun@cisco.com
Description:
Community Member
problems
David Dunlap
& CCNA-Voice
Community Member
Errr back on topic
Cheers,
David.
3321
