Community Member
UC540 no incoming calls - Debug isdn q931
Hi Community!
This was my first post and I hope, that someone could help me with my missing knowledge about the configuration
I had a huge problem with my dailplan of an existing UC540 with incoming calls. Outgoing are working fine, but if somebody call the main number or any other extension number except the existing phone extension (100,200,300,888,...) then I get a "This number can not be reached" from the telefon provider. I can not find out wich number the telco is sending maybe there will be the problem. Attached you will also find the dailplan that I use.
At the first calling party number is my phonenumber to see, but actually we use a "0" on the beginning.
What is going wrong here?
Thanks a lot fo your help,
Christian
UC540#
000756: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x01
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8483 - Origination address is non-ISDN
        Date/Time i = 0x0B02011239
                Date (dd-mm-yr)   = 11-02-01
                Time (hr:mnt:sec) = 18:57:108
        Calling Party Number i = 0x2183, '277343163'
                Plan:ISDN, Type:National
000757: ISDN BR0/1/0 Q931: TX -> SETUP_ACK pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
000758: ISDN BR0/1/0 Q931: RX <- INFORMATION pd = 8  callref = 0x01
        Called Party Number i = 0x81, '0'
                Plan:ISDN, Type:Unknown
000759: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling
num 63
000760: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0017 callID = 0x8017 switc
h = basic-net3 interface = User
000761: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
000762: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x17
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
        Channel ID i = 0x82
                Preferred, B2
        Calling Party Number i = 0x2183, '63'
        Sending Complete
000763: ISDN BR0/1/0 Q931: RX <- STATUS pd = 8  callref = 0x97
        Cause i = 0x82E41E - Invalid information element contents
        Call State i = 0x01
000764: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x97
        Cause i = 0x829C - Invalid number format (incomplete number)
000765: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling
num 63
000766: ISDN BR0/1/1 Q931: Sending SETUP  callref = 0x0018 callID = 0x8018 switc
000767: ISDN BR0/1/1 Q931: TX -> SETUP pd = 8  callref = 0x18
                Standard = CCITT
        Channel ID i = 0x81
                Preferred, B1
        Sending Complete
000768: ISDN BR0/1/1 Q931: RX <- STATUS pd = 8  callref = 0x98
        Call State i = 0x01
000769: ISDN BR0/1/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x98
000770: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
        Cause i = 0x809C - Invalid number format (incomplete number)
000771: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
000772: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
UC540#
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Channel ID i = 0x89
                Exclusive, B1
num 63
                Standard = CCITT
        Channel ID i = 0x82
                Preferred, B2
        Sending Complete
        Call State i = 0x01
num 63
                Standard = CCITT
        Channel ID i = 0x81
                Preferred, B1
        Sending Complete
        Call State i = 0x01
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Community Member
Hi Christian,
Wecome to the community.
The key lines from your debug are:
I would have your carrier check your IDSN config, and also confirm your trunk settings.
The above would indicate the number you are calling from is '63' - not sure what country has such short numbering, and the number being called is '0' - again, pretty useless.
Perhaps check your port settings under Telephony -> Ports and Trunks -> PSTN Trunks -> BRI and check your settings. Not sure what country you are in, but in Australia we use BASIC NET3, None, 0, which seem to work for us.
Cheers,
Scott Martin
Community Member
Hi Christian,
Can you give us a quick run down on the ingress call flow topology?
For instance, what number is being dialed, where you expect that number to go, and how have you programmed this to work, was CLI used or CCA?
I have a feeling it is a dial-plan issues, which means it can be resolved easily enough
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Community Member
Hi Christian,
Cheers,
Scott Martin
Community Member
Hi Christian,
Cheers,
David.
Community Member
Hi David, thany you for your re.
We used the CCA to configure the UC540 and the phones. You are right it was a dailplan issue that can only fixed by using the CLI. We spend a lot of time to to find out how ISDN (Telekom) works in Austria, because it is a little bit different to other contries. The debug log is correct and show us only the digits you dail more then the headnumber.
For example the headnumber is 02773 123456 and you dail exactly this number you get "" (nothing) back. If you dail 02773 124560 you get "0" back. If you dail 02773 12456800 you get "800" back and so on.
During this projekt we found out a lot (to much) how it´s running with the telko in austria, so we know how it works now and in the meantime we installed a lot of this UC540 device on different places in austria. With the UC540 you got a pretty cool device!
Thanks David!
Cheers,
Christian
2862
