Community Member
UC540 no ping response
                   Hi All, we have a UC540 installed with remote VPN phones, after changing the exyernal ip address and deleting and recreating the NAT rules, the computers behind UC have internet connection , but the UC itself has no internet connectivity(tested through ping command) and there is no access for VPN from outside, any ideas?
1 REPLY
Hello Robert,
You should check the ACL attached to the WAN interface.
Also you should change the ip address of the ssl vpn gateway.
If you are using CCA you just delete SSL vpn and add it again also you may look for the access list attached to FE0/0 and change the old ip address with the new one. Also check the name servers set for the UC.
HTH,
Alex
*Please rate helpful posts
280
